SOLD 1967 date Alternator core
go-fish
10:52 AM
CA
Feedback: 1 / 0 / 0
Alternator core that has what I believe to be November 1967. Could be used for a ‘68.
Pretty sure it is non-op but could be a good core. Has a two groove pulley.
$30 + shipping OBO. Coming from 91901
ready to get rid of this thing.
You need to post a pic with the part number on the flat pad, and both pie wheel dates . That will help you sell it as it gives details of the application... good luck!
The back seems to match the front.
What do we have here?
Looks to be a nice item, probably been rebuilt as I noticed it doesn’t have the bullseye rear bearing. Top 3 digits are vender code, next row is part number which would match a few numbers on a build sheet, next line is assembly date of the entire unit. I’m more familiar with 1970 units but Jim Ridge at Dixie Resto maybe interested, give him a ring. They are not really super valuable in core form but you maybe able to help a guy with a 68 that’s getting redone! It really takes a lot to make a car right by the numbers like this alternator, two case halves , and assembly dates all gotta jive and the pulley needs to be the correct part number, right bearings and color windings, field, diode packs etc.. Jim is the guy to give a call if nobody jumps on it.
I may have the correct color field coil NOS if you need it.
