WTB 1966 B-Body automatic steering column assy
65AFX
3:37 AM
Arizona
Feedback: 3 / 0 / 0
I need a complete 1966 automatic shift steering column. Would be nice to have all the linkage. I have installed a newer big block 727 transmission with shift linkage in my 1965 Coronet.
I have this one from a 67 Satellite, column auto., PS. PM me if this is of interest.
I believe you will find that the 66 is a 1-year only column. The 67 is slightly larger (in diameter) and will also collapse. I myself have been looking for a 66 column, column shift with Power Steering.
Yes, only 1966, as I do not want a collapsible column.
No, I want a column shift. Also If it was a column shift I don't know if I can make a Monaco C-Body work.
Hey Don, We do have a couple of 66 steering columns.. the one out of 66 Belv
that was manual steer, but my brother just informed me that he thinks we sold
the manual steering shaft out of it, but I'll check on it. Also, should have one
out of 66 Coronet, but its power steering, IIRC. I'll check on it for you.
I have manual steering box, but I can but a shaft adapter to use on a power steering column.
If its a BB block car I can also use the linkage. Actually any linkage from a 66-71 BB 727 will work with minor mod's.
I got one from a member. Thanks FBBO.
