SOLD Misc b-body parts
pnora
1:50 PM
Ishpeming, Mi.
Feedback: 7 / 0 / 0
These are whats left from my 69 Dodge Charger project. Most are used and the ones that are new are marked as such. I have pictures. Prices are negotiable and shipping will depend on how much you bought and where it is going. PM me here if interested.
Defroster tubes 20.00
Console lights 25.00
Console end plate 50.00
Glass all clear 7 pieces 300.00
Dash face plates [black] 200.00
Console shift plate automatic 150.00
Console door 80.00
Console end piece 45.00
Console hinge 10.00
Left remote mirror 100.00
Circuit boards 50.00
Charger c-pillar name plates 60.00
Rear window inside trim [new] 100.00
Sill extension plates 20.00
Sill Plates 40.00
Rear window stainless moldings 100.00
Glass all tinted 7 pieces 400.00
Vent window frames with lower brackets 250.00
Left vent window frame no bracket 100.00
Dash and kick panel insulation ?
Inner door handles with screws. 20.00
Gas filler tube and vent line powder coated 50.00
Brake pedal assembly automatic 100.00
Rear lower shock washers and nuts 5.00
Wiper switch 2 speed 50.00
Wiper motor 2 speed 50.00
Wiper motor crank arm 2631794 50.00
Vacuum headlamp actuators 150.00
2 speed wiper harness 20.00
Proportioning valve 25.00
Brake pedal automatic 25.00
Heater hose bracket [new] mp101-hhba 15.00
Sail panel right repair new yo mx39rh 25.00
Steering column 150.00
Heater box 150.00
Torsion bars 778 and 789 100.00
Front park brake cable, equalizer, nut. 25.00
Charger tail panel emblem 20.00
Misc under hood components 10.00
Headlight door emblems Charger and logo 60.00
Front brake backing plates 10 x 2 1/2 new shoes 80.00
Pitman, idler, ball joints, tie rods 100.00
Front sway bar and hardware 150.00
Front bumper with bumperettes new AMD 225.00
Glove box insert 1 5.00
Bumper rear with brackets and bumperettes has dents 200.00
Heater cables temperature and mode 20.00
Dual front speaker mount homemade 10.00
Right heater fresh air vent cable 30.00
Blower switch 10.00
Transmission back up neutral start harness 20.00
Throttle Cable new Mancini 33-371 50.00
Front tie bar K to core bracket 10.00
Mirror outside 2299521 62-66 dart? 25.00
Seat belt buckle holders and misc. 10.00
Power steering pressure hose 5.00
Brake lines master to proportioning valve 10.00
Rear bumper with bumperettes ok driver 150.00
Front bumper with bumperettes ok driver 150.00
PRP Throttle mount #1028 new 40.00
Prowler patches 10 5.00 each.
Shift boot new 60.00
Cat whiskers front door inner 10.00
Door weatherstrips 25.00
Front fender seals. 10.00
Hood seals 25.00
100_2148.JPG 100_2250 (2).JPG View attachment 1117378 100_2296 (2).JPG 100_2418 (2).JPG View attachment 1117381 100_2326 (2).JPG 100_2303 (2).JPG 100_2447.JPG 100_2273 (2).JPG 100_2197 (2).JPG
Interested in your steering column. Looking for a floor shift column from a power steering car.
