tom jaffeux
Need some information. What would be a good gap between the radiator and clutch fan or is it best to use a flex fan and can I use a shroud with a flex fan
Are you starting from scratch? If so my advice would be to have the radiator installed and measure the distance from the face of the water pump pulley to the radiator fins...then find a clutch that's 1/2" to 3/4" shorter than that. That should put your fan blades in a good place inside the shroudNeed some information. What would be a good gap between the radiator and clutch fan or is it best to use a flex fan and can I use a shroud with a flex fan
