Tire and wheel size for 65 Coronet
ss1gtx
10:56 AM
brooks ky
What is the widest wheel and tire you fit under a 65 coronet without doing any mods?
275/60/15, or 295/50/15 for the rear. 245/60/15 for the front.
Rear will depend on backspace, front use a 4 inch backspace.
criterion rv8 038.JPGcriterion rv8 023.JPGI have I believe 275/50/15 with 10" steel rims on a 65 satillite but, I don't remeber the backspace on them I had them custom made.criterion rv8 033.JPG
I have a stock 1965 Coronet with 12" ( 305 mm ) wide Mickey Thompson Sportsman SR on my rear with 10" x 15" x 4.5" backspace wheels. I had to install new springs to keep the rake of the rear of the car up ( not a lot though ) they fit and look great.
I have 275/60/15s on 15x8 TT w/4" backspacing in back. They required minimal clearancing on the inner fender well to work nicely on my '65 Coronet wagon
IMAG0410.jpgIMAG0408.jpgI went with 275/50/17 tires on 17x8 rims with a +12mm offset (5"). Tire gets pulled within 5/8" of the leaf spring.
Rear Wheels
Have a picture form the side and back of this setup you can post?
Pictures and new plan.
I have posted some semi clear pictures (my new smart phone sucks) of my set up as it is now. I have the shackles on yet that I used to get my baseline of how much arc to put in the new springs. They fit and I have had people ride in the back with no noticeable bottoming out or tire rub. My new problem is I bought 26" tall tires that matched the factory height so I wouldn't have to change the speedometer gear. I do not like the look of the 26" tall tires and if I go with 28" or 29" with my current set up I will have tire rub issues unless I jack up the back more which I don't want to do. My plan is to mini tub & narrow mine and solve the problem once and for all. If that option isn't for you then I would recommend maybe going with 295 mm or 275 mm as you should be able to go taller if needed with no issues.
Can anyone explain to me how to size my pictures when I upload them because on my phone they are much clearer and smaller then when I post them on the site?
I have 275/60s on my 63 with 8 inch wheels 4 1/2 inch back space they fit great
Before I mini-tubbed, the biggest tire I could fit on my '65 Coronet was a 275-60X15 on a 7" wheel with a 4" backspace. After minitubbing and moving the springs in, 12.5X29.5X15 Hoosiers.
Pictures
Have any pictures? I am a visual guy. Did you fab the minis or buy a kit? If kit where?
just got a set of cop rims. lots about the rears what about the front?
I like that look aldal. Did you have to relocate the spring mount or is it still stock?
Please clarify..Did you fit this tire on those rims under a bone stock 1965 with only more spring arc. No recolation of springs? looks like your wheel well top is only about 1-1 1/2 inches above the rim beed?
I have 275/60/15 on 15x8 4.5bs on my stock 65 coronet. I have to keep air in the rear shocks or I do get rub around turns on the inside of the quarter.
Mine was stock but since that picture I have had the springs moved, mini tubbed and the frame notched to fit wider tires.
Does anyone know if a 18” x 7.5” (+50) rim fit under a stock 1965 Dodge Coronet 440, 4 door? Front and rear? There is a great deal on FB.
Thanks, Henry
