I have an almost new master for it if you're interested I'll send it to you.
Needs more cam!. Sounds very good.
Sounds great! A little more info on the build??
470 stroker trick flow 270 heads Indy intake cam is from Dwayne Porter 646/653 lift HS rockers too small headers because low deck and 2 inch headers are a pain to fit on a B bodies 3 inch exhaust, 67 Plymouth 4.30 gears with 29 tall tire, sent my 1000 cfm carb to Jesse at Biggs 8 inch converter
