Stock auto Consol fit over a six speed
72duster72
12:08 AM
castle rock co.
Stock auto Consol fit over a six speed . I have a 69 road runner with six speed has anybody used a stock automatic floor consol to fit over the 6 speed if so any pictures
On my TKO 5 speed I have the automatic console, with the 4 speed manual top plate. I also have the designed 5 speed handle and the off set adapter that goes on the transmissions shift stub and then the handle attaches to the adapter. You most likely will need to measure your shifter and compare it to a 4 speed console car.
This is in my 67 satellite with the t56
Not sure why my pic is sideways??
I built a custom console when I had a 727 in it and it still fit after installing a T56 so??
Do you have pictures of your custom consul. And the one that has the 67 satellite with the shifter curve like that I have to look and see if mine shifter that curved or not
Consoles are the same, it’s the top plate that is different for auto or stick for the year of car your talking about.
The consoles are different between automatic and 4 speeds. They fit the same but the 4 speed has a cut out to fit the 4 speed tunnel kick out.
That I am aware of. I will get a automatic consul because the floors replaced with an automatic floor
