IMO...
The carb date SHOULD proceed the build date of the engine and car. As others have pointed out, the carb is a '70 model application. What makes it different? The '70 emission specs were different than the '69 specs so the jetting, step up rods, step up pistons and springs will likely be different (leaner), and the off idle air bleed transition circuit will be different AND the addition of a HOT IDLE COMPENSATOR VALVE, (located above and between secondary butterfly valves, below the air valve blade) for A/C option, to add additional air to the idle mixture for a smoother idle due to high underhood temps. Perhaps your original carb was replaced with this unit due to a warranty replacement??? The -----SA, means the "A" is an engineering revision to the origional issue. Just thinking out loud......
BOB RENTON
