Switching from ATF to gear lube in my 83 300D. Any problem with the two mixing is there will be some at the bottom of the trends that won't drain out? Damn spell check!
Don't I know it !You can mix astroglide with k-y but does not work well with bengay.
Seriously? No real answers?You can mix astroglide with k-y but does not work well with bengay.
WTF B Body is that? We supposed to have known this? sheesh......
