WTB 1967 b-body floor shift steering column
bbbb
7:48 PM
santa rosa ca
Looking for a 1967 b-body floor shift steering column. For my Belvedere five speed swap. Thanks
Went through this on my 67 gtx restoration and Tran switch to 4/s , ended up , using the original column shift one , minor modifications and your set mainly ,upper collar and removed shift arm at bottom, collar can be modified easily and your good to go
Thank you, I figured there would be a way to modify the existing. Mopower
