Rooster27
Hey guys and gals hope all is well! I bought a set of 1967 charger sway bar bushings because the originals were shot and I was getting getting cluck/knock noise when I would accelerate. All of the bushings are the correct part number and were a bitch to press into the strap that connects to the lower control arm shaft, now my problem.is getting that strap that contains the bushing onto the sway bar. The hole is squished and mush smaller than the bar which is obvious because they are new. The strap and retainer that holds the bushing is welded and I would hate to cut it and re-weld, if re-welding is necessary. Is there any advice on how to get that back on the bar? I have lubed the **** out of it and am now boiling the whole piece in hopes it makes the rubber more plyable.
