- 4:10 AM
- Nov 21, 2008
- In GTXtacy Illinois
Gents!
I am attempting to tune my Leaning Tower of Power and need advice. I get that she's a slanty, but the basics should be pretty much the same. (I posted this over on FABO also fwiw)
That being said, it was tuned by the PO and I have never fooled around with it, but my spidey senses are telling me she's not quite right and needs tuning.
Specs:
-225 slant with unknown cam (it's obviously not stock and pretty hot from what it sounds like-see vid)
-Edelbrock 1403 500cfm carb
-Offy intake
-Clifford headers into dual tailpipes
-new black Mopar ignition box from Ray (halifaxhops)
-new ngk ZFR5N gapped at at .030
-initial (just hooking up the light-with advance knob at 0 and pointing) timing at 0
-15 hg of vacuum hooked up to manifold port
-distributor is hooked up to ported port
Now, it has been quite a while since I've tuned a carb (it was my GTX like 10 years ago lol) so im a little rusty. The vacuum is jumping around at idle A LOT and I think that means there is a leak somewheres. I put my hand over the carb and it does not die. Let's start with this and proceed from here.
Thank you for any and all help Gents.
Specs:
-Offy intake
