Talk to any machinest and see what they say. Of course we each have our own ways of doing things. Kim
My machinist says cut the intake surface of the heads.... Think about it, why make an intake unusable with every other set of heads? So you do it and the parts get separated, now you have a set of heads floating around that won't seal to other intakes and an intake floating around that doesn't seal to most heads.... Brilliant!! Or you cut the intake side of the heads at the same time your cutting the head gasket surface and the heads can be bolted to any other block or intake with no issues.... Explain to me why you would want to do it the other way?
