Ryan Edwards
Hi all. Just want to get everyone’s input on an issue I came across while building an RB stroker. Finally got my Edlebrock 7193 Performer Intake today. Tried dry fitting to my trick flow heads and the underside of the manifold is hitting my aluminum valley pan. The underside of the manifold hangs down quite a ways where the cross porting passage is to equalize the pressure between heads. The trick flow heads are not ported for this anyways. I am using a flat plate for a valley pan with facing gaskets similar to the 440 souce one rather than an OEM valley pan. Thoughts on milling off this passage on the manifold to clear?
