Ok. explain on how gas and diesel do not mix.Just telling you what I actually experienced... But hey, don't let that get in the way of your opinion...
Bull crap. Diesel fuel and gasoline are each a blend of hydrocarbon compounds derived from petroleum crude oil. If these compounds are mixed, they will remain mixed and will not separate unless they are subjected to a distillation process (heating and condensing the vapors at the appropriate temperatures
I've mixed the two fuels plenty of times; draining old tanks and using the mix for degreasing. They seem to mix just fine, never seen them stratify. But if the diesel did float on top, it wouldn't have entered the pick-up and been fed to the engine.I can't honestly say it was a quart or two quarts... It wasn't much... You could see it floating in the gasoline, they didn't mix, it was pretty obvious what was diesel & what was gasoline... And you could smell the diesel over the gas fumes....
And if your trying to impress us with how smart you are... I can cut & paste too... But I try to make a point of crediting my source... I mean you even kept the quote about heating & cooling vapors....
I just found a simple explanation. So quit crying just because you got busted. You just got a taste of your own medicine.
Explain how I screwed up. I also spend time trying to help people. In the past you have made jabs at my comments. So get over it. I am.My own medicine? Really? I spent time trying to help people & you see that as somehow bad? Your screwed up...
I already admitted that your were correct about fuel & gas mixing but with the stipulation there was definitely something that didn't mix.. End of the day the important take should be drain the fuel, flush the system & replace the fuel filter... And hope the guy gets lucky...
Extra fuel while not looking, luv it. Kinda like co-workers dumping a little oil under a Harley!!!
Thats a great gag!While we're talking about Diesel fuel, a fellow I worked with bought a diesel Rabbit in the early 80's. The guys would keep putting diesel fuel in it so he thought he was getting a 100 MPG with it.
I did a similar thing. I took Dad's 1 gallon "gas" can and put the contents into my 69 Dart....I worked with a guy that put Diesel in a mid 70's Ford station wagon and that car literally smoked till that got rid of it. Looked more like a 2 cycle engine running.
