SOLD 440 Source Stealth Heads
brian.linn
8:35 AM
Conway Springs, KS
Feedback: 1 / 0 / 0
Purchased these from a guy who had them in a dyno, I took them into a very reputable shop who freshened them up and did some light blend work. Ready for your cam Springs and run. I have $2200 in these heads. $1600obo. Will ship at buyers expense.
I’ve got the valves and retainers. Everything has been marked to go in the correct hole...
D1BD7A94-4CD7-486E-914A-103FC4217F0F.jpeg A3E67A3B-FF40-4BBD-BBE2-DA40A9B51DE8.jpeg A0D697C7-FB60-4142-AA42-66B579675562.jpeg DD432054-4630-4E4B-818A-54FAA99E5967.jpeg
just remember the push rod clearance holes need work unless your running all stock stuff . anything other than stock you'll need to fix the clearance issues , even 5/16 pushrods .
What all was done to them porting wise? Any flow numbers?
No flow numbers, no porting. Hot Tank and blasted heads, added new mag bronze guides, cut valve job, detail blend work short turn.
