Does this look correct for 318 rocker arm placement, or should the arms be reversed to change the position of the push rods?
View attachment 1150319 View attachment 1150320
Can you get the oil pan off?Guess it is time for a new cam if I cant find the hair pin. At the very least the manifold has to come off!
Ho-lee crap dude!Ok, I am officially confused. Seems like the consensus was that the cups in the rocker arms should be placed on the rocker shaft so that they are nearest each other when installed (318 LA). However the FSM seems to indicate they should be placed so they are the furthest apart. What I have now:
FSM:
View attachment 1162474 View attachment 1162475
Seems like I have them correct, BUT if so what would cause this?
Pushrods all seemed to be seated correctly.......
Lifter faces and barrels looked great. Cam lobes looked fine except uneven wear pattern.Ho-lee crap dude!
On LA engines the pushrod cups sit farther away from each other, not closer together. The FSM is correct....If you ran them as shown here you had them right.
As far as the destroyed lifters?? Maybe, burrs/rough edges on the lifter bores in the block? Lifters incorrectly assembled? Not sure if a lifter that stopped rotating could break like that, but what do the lifter bottoms and cam lobes look like?
