...when the non functioning a/c on your plow truck loses the clutch bearing and you don't want to reinvent the wheel to engineer a new belt routing from eliminating it?
Well add ANOTHER alternator!
I upgraded the stock 60 amp to the big frame 100 amp and added the 200 amp Leece-Neville where the smog pump was several years ago and eliminated any charging problems, the new 90 amp Denso is just showin' off
