aussiewannabee69
Hi all. I Was in the first stage of cleaning up my engine bay, cutting and smoothing it out. First part was the battery tray, at some stage in its life it had been given a fibreglass patch. At least that won't rust.
So I cut that out and then thought about making the frame rails look nicer by boxing the top in. My plan was to drill all the spot welded plates on top of the frame rail and replace with one plate welded on and given a smooth appearance. I didn't worry about using my spot weld drill bit because those parts are going anyway. Once I got the tops off I found the frame rail to be rusting from the inside out.
First question, how hard are they to replace?
Any good threads to follow on replacement?
AMD are out of stock. I see Sherman have some on summit. Are they any good?
In the last image is that part of the shock tower?
