With the motor in I trying to figure power steering hose. I have 2 pressure replacement hoses. Sure doesn't look right.
Are you required to bend the ends or these are not correct? If to be bent is there a pattern out there?
Thanks
Oh, that doesn't look right at all....of all the lines I have seen, none have straight ends.
I think the proper routing is out of the pump and go towards the radiator, under the battery tray then back to the gear box. Requires curved ends though.
