think spindles are one sided - if they're switched the drag link be up front somewhere.
Upper control arms are right rubber bumpers are forwardUpper A wrong side? Spindles no L/R think they're the same.
I think they were a option11 x 3 brakes, on a 65 Coronet? Is that factory, or were they swapped from something else? I would not think 11 x 3 would have been available on a 65 Coronet?? (I may be wrong.)
Middle photo. What is that nut and bolt with the bolt shank partly exposed? Is that supposed to be for a sway bar? No bushing?? I'm confused.More photos.
Alignment way off?
View attachment 1229702 View attachment 1229703 View attachment 1229704
Is where the sway bar bolts to the strut there is a bushing just can't seeMiddle photo. What is that nut and bolt with the bolt shank partly exposed? Is that supposed to be for a sway bar? No bushing?? I'm confused.
