1970 GTX center dash duct for AC
Mark Pifer
9:14 AM
Venice, Florida
Hi,
Does anyone know where to get the charcoal foam gaskets used between the air conditioner/heater unit and the center connector duct? If you cut out you own foam gasket what specific foam material have you seen work the longest before needing to be replaced again?
The center connector duct then attaches to the dash center vents. See 3 attached photos.
- One photo shows opening on air conditioner/ heater unit.
- Another photo shows center connector duct
- Third photo shows charcoal foam attached to the other end of the center connector duct.
Thank you for you help in advance.
Screenshot_20220316-185428_eBay.jpg Screenshot_20220316-185417_eBay.jpg 16474863936676354246510252321192.jpg
I did a search and there are a lot of listings. Just look up heater box foam.
Thank you, I spoke with Detroit muscle technologies. If you send the duct he can cut out the foam gasket. Otherwise he does not have that particular foam gasket.
