I would regulate that down to 5 or less just to be safe. Edelbrock carbs will dribble fuel with not much more than 5#.Yes, new, around 6, bounces a bit
What octane fuel are you using? Race fuel isn't around hereM/car,
Idle timing is a most understood topic, even amongst seasoned mechanics. The lower the idle vacuum, the more timing that is a needed at idle. Unless you are using a programmable ign 'box' [ & you don't need one ], the best way to give the engine the timing it WANTS is to use a dist with adjustable vac adv. Very cheap from Summit, $140. Set the Allen Key fully CW. YOU DO THE INTERNAL CENTRI CURVE LAST, NOT FIRST. Connect the VA unit to manifold vacuum { MVA} [ ported is USELESS ]. See link below. My engine idles @ 48* BTDC. Yes, 48, not a misprint.
D. Vizard has authored 30+ auto books, forgotten more than most will ever know.
Below is from a carb book, not an ign book. Hmm....
'The optimum idle advance is typically about 35-40* for a short cammed street engine & though not commonly realised as much as 50* for a street/strip engine'.
And from PHR magazine', Nov 04, while reviewing a new Crane dist:
' At idle....the amount of advance to most effectively utilize the air & fuel entering the engine can be as much as 50-55*. This is handled by the vac adv....By taking the time to hook up the VA to a manifold source you can get that big cam to idle as it were 20* less than it really is'.
Cannot stress enough how important this is to getting optimum carb performance & idle. Mopar missed the boat on MVA, GM used it & got it right.
More on MVA, scroll down to post #6.
www.hotrodders.com/forum/vacuum-advance-hooked-up-directly-manifold-bad-47495.html
Agreed. Post #9 was my condensed version. Nicely explained, Dragon.You missed my point. You're diagnosing and you know nothing about the patient. Ignition system, amount of mech advance total, and how quick it is in, vacuum can max adv, etc... I have seen folks dial in 20 plus initial not realizing that the distributor cam of a 70ish mopar could add 30 to 34 degrees timing. Plus they removed the heavy spring and all in at 1500rpm. At wot they have 50 plus degree. Vacuum cans can add 26deg or more timing.
This is all about idle timing, ported is nothing more than an automatic switch turning on the vacuum can as throttle blade opens. Each carb has a point where that occurs. When the port is uncovered and exposed to manifold vacuum. For Chrysler in stock form, as you accelerate mechanical advances and vacuum may starts to add too, unless a WOT acceleration. So both maybe adding.
In your case to compensate for a mismatch in components CAM/Carb. You Add via vacuum initially, so what happens when you accelerate. Again you have mechanical add, and maybe a little vacuum or maybe it starts to retard. That graph is completely different looking than a stock set up. So is it as good? You say yes, others say no.
Also, so why does vacuum increase when you advance timing?
Just as a comment on 6bbl instructions, which I like, you don't want fully closed throttle blades do you? I think you want a portion of the transition slot uncovered for proper mixture volume. Once your satisfied you might need to adjust pump shot too if any stumble off idle.
