Dvw, you have taken such care in building this power plant and glad to see that you are still moving forward. Some setbacks but nothing you can't control. I'll continue to get my brain feed from watching you. Thanks
he good, the bad, the dumb. I trusted the person who ordered my pistons. Bad move.
At 4.350 they’d be intruding plenty. I’m assuming that’s a typo?The Cometic head gaskets arrived. Perfect size 4.350" bore on my 4.530" block . Installed the pan studs with some blue locktite. Checked the head gaskets on the block to make sure they didn't intrude into the bore. ]
After using pin buttons, I’ll never order those pesky spirolox on custom pistons again.Shocks are shipped. Axles at the machine shop. Sanded the sharp edges left from the valve pocket machining. Cleaned everything up. Reinstalled the rods to the pistons enjoying all 32 Spirolox. Rings reinstalled. Pistons and rods back in the block. Torque and check rod bolt stretch tomorrow.
Very nice setup. That's the right way to do it.Shocks are shipped. Axles at the machine shop. Sanded the sharp edges left from the valve pocket machining. Cleaned everything up. Reinstalled the rods to the pistons enjoying all 32 Spirolox. Rings reinstalled. Pistons and rods back in the block. Torque and check rod bolt stretch tomorrow.
Clearanced a lot of those. Did a few with teflon blades that were nearly zero clearance. I wish I would’ve done some before and after dyno testing.View attachment 1264094 Didn't bother to measure the weight. You would be amazed how much weight you can take off a piston and not create any issue. Got the rod bolts stretched today. There is no real torque spec. The electronic torque wrench reads the achieved torque while completing the 60 angle. The reading varied so i had my doubts about zeroing in on the required torque. Turns ot (82lb/ft) to get the required stretch. Others had suggested this method. So I tried it. It appeared to me to be even more accurate than the 40lb/ft +60 degree method. Then spent a good amount of time fitting the crank scraper. File, grind , clean, fit. Then repeat more than a few times. The end result is a very close fitting assy.
—-I actually have Spirolox done pretty well. Its had 1/2" studs since new. After doing some paint touch-up over the winter I got to thinking about it. It would be a shame to break a wheel off and wreck it. Though I can say it's never had an issue with nuts coming loose or bending studs. Though my sons turbo car with stock steel wheels bent 1/2" studs. Would've done it a while ago. Just a little tougher to do with the old Americans. The spacers need to be trimmed to 1.125" diameter to clear the wheel.
