WTB 1966 426 Hemi Harmonic Balancer
Hemi2Much
7:18 PM
Alabama
Feedback: 2 / 0 / 0
Looking for a GOOD 426 Harmonic Balancer. Mine appeared to be good but after the machine shop checked it out it is torn.
I think they are the same for 440 and 426.
If you have anything please contact me through DM.
Thanks, JKent
They can be rebuilt/revulcanized. I had my 318 poly damper done.
Mike
66 Harmonic damper is Hemi only, thicker than a 440. 493 Mike where did you get that done. Check key way for crack in corners, stick cars can crack them.
I have a good harmonic balancer that is the same thickness as 426 Hemi, but a little smaller diameter. Message me and I will send pics
I'll look into that. Can you tell me who you went through to get your redone?
Thanks, JKent
Sorry to be so late with a response. I used: Welcome to Damperdudes.net
I was mistaken though as they revulcanized the A/C drive pulley (weighted) for my 318 Poly. They may be able to rebuild your damper though, call them.
Mike
The machine shop said the keyway has cracks. Do any of you know if they can fix the cracks?
