67 TRW power steering pulley
bobbio
9:22 AM
Mechanicsburg, PA
I ruined my P.S. pulley for my 67 TRW pump using a jaw puller. The pump is on a 67 Satellite 383 4 speed car. To make matters worse, I knew better. Long story short I need a replacment pulley and have not had any luck yet out on the net and was hoping someone here may actually have one.
Press fit
Pulley O.D. 4.75"
Bore size about .625"
Offset away from pump towards radiator of about .75" from the back of the hub to the pulley centerline.
If anyone can help save a dumb*** I sure would be grateful.
I checked 440 Source last year and agan today, they only stock saginaw pulleys. I need a TRW.
I did the same thing with the same pump last week! I can find that pulley anywhere. So please let me know if you find one or a way to use a different pump that lines up.
