FOR SALE 1964 Dodge 330
Babblingtabbies
7:35 PM
Nebraska
Dodge 330 2Dr Post Ramcharger. Dodge 330 2 Door post sedan. Recently built & never raced 512 cid engine assembled with 440 source 17 cc dished pistons, Ultralight stroker crankshaft, and Platinum series connecting rods. 10.5 to one compression makes it good for use with pump grade gasoline. 1964 Stage 3 intake manifold (un cut) with Edelbrock AFB carbs on top. Lunati solid flat tappet cam shaft. Edelbrock Victor heads with Hughes Engines offset intake rockers. Charlies aluminum 7 quart oil pan with passenger side kick out. MSD digital 7 ignition, MSD coil, and MSD spark plug wires. Milodon billet oil pump. Can use Max Wedge velocity stacks or custom air filter assemblies. Griffin Thermal Products cross flow aluminum radiator, dual Spal electric fans, and Flowkooler water pump. TTI 2 1/8" inch ceramic coated headers (2 1/8 inch sized tubes). Flowmaster 3 ½ inch mufflers (installed for local sound ordinances). Fluid Dampener harmonic balancer. One wire Denso alternator charging 2 trunk mounted batteries. 727 Dodge TF transmission with heavy duty clutches and bands. ATI 10 inch stall speed torque convertor. Dynotech carbon fiber driveshaft with safety loop. Dana 60 differential with Strange axles. Full race suspension (forward bars, rocker bar, and ladder bars with coil overs) installed by MPR race cars. Competition Engineering front and rear race shock absorbers. Front and rear Wilwood disc brakes with Bogart aluminum wheels. Mini tubbed to accept 10" rear wheels. Mickey Thompson front and Mickey Thompson street/strip rear tires. Aeromotive fuel pump and fuel filter with 8 gal fuel cell in trunk. Paint done by Autocrafters in Oxford, MI (base coat clear coat) in 2005. Fiberglass hood, front bumper, and max wedge hood scoop. Plastic (Plexiglas) windows, rear glass, and windshield. Gary Balls full interior; super stock seats, aluminum seat mounts, door panels, carpeting, and head liner. Precision automatic transmission floor shifter. Painless Ignition rocker switch box with starter, ignition, water pump, and fan rocker switches mounted on 7 point NHRA approved roll cage. Much more invested in this car than what we are asking (what's new there?) Great car for high performance street, nostalgia super stock, pro or super pro! Email with any questions. Great Mopar car to show or race, or even drive down the street. Thanks for your consideration.
Price $ 35,000
