1964 Dodge ignition switch bezel
500Hardtop
10:05 PM
Aurora, CO
Does anyone have the tool to remove or install the bezel on the ignition switch?
Thank you,
Dave
If it is the same as a 64 Fury, I loosened the bezel by using a pair of needle nose pliers.
Small tips, stuck into the 2 holes on the inside edge to loosen and then unscrew the rest of the way by hand
Ed
Check out Classic Industries part #MF1742. Some on ebay also
MF1742 - 1962-74 Mopar; Washer, Wiper, Headlight Dash Switch Bezel Nut Removal Tool
I have this tool it will not fit the ignition bezel
I missed that, thanks. I'm going to delete post because i don't want to pass on bad info. Good catch.
Snap ring pliers with the larger tips work fine if it wasn't put on by a gorilla..
