bb70duster
1964 Plymouth Belvedere I, 2 door sedan, real 63 426 Max Wedge block, Indy 440-1 Aluminum heads, Mopar 4.150” Stroker crank, correct 64 stage III Cross ram and carburetors, Headman headers, full 3” exhaust with cut outs, push button 727 trans with 10” converter, mini tubbed, narrowed Dana 60 rear end with 3.73 gears and a locker, Centerline Convo Pro wheels, disc brakes, car started as a rust free CA car, (original engine was a 318 V8) original black plates, very nicely built car, Chrome was completely redone, nice interior, all gauges work, recently car picked up a misfire, under inspection I found a piston broke at the ring land, so will need a piston replaced. Car does still run, no other known damages. Title in hand. Fix it yourself and save some $... $28k as is
