timsatellite
Does anyone have a picture of the correct original manual shift valve for a 1965 cable shift rear pump 727? The incorrect manual shift valve was installed in mine and need to figure out the correct one to reinstall ... and a picture of the correct one would be very helpful. The trans guy has it in his shop ....just need to get the right one and maybe match it up so i can get it right.
the picture is the one i took out - it will look very similar to the attached picture however the spacing of the groves and valve port will be slightly different. if you have one ( I know these are not a common item).... and can take a pic on a tape measure that would be a huge help in confirming i get it right this time.
