Dan Schilla
1965 Dodge Coronet recently pulled out of storage. V8 Auto car. Complete fuel
system flushed and upgraded with new tank/sending unit and pump along
with carburetor. Entire cooling system flushed and replaced water pump and
radiator. Complete brake job including all new pads and hardware inside,
drums have been turned.
Its just been too cold and too much snow in N.D. for the final test drive so im
sure there some bugs still needing to be worked out.
It will move on its own power gears seem to work forward and reverse.
Compression test was good on all cylinders. Starts and runs smooth.
Top works up and down.
Body and interior is OK, I would one day replace with red interior and new
paint. Has dings dents and imperfections.
Clean ND title in hand.
Things already done:
New Radiator
New Fuel tank
New Tires all the way around
Ignition lock
Ignition switch
Trunk lock
Horn ring
Radiator
Master cylinder
wheel cylinders
hydraulic hoses (front)
belts
radiator upper hose
radiator lower hose
transmission filter/gaskets
brake pads (4 sets)
wheel seal (2 front)
drum brake hardware kits
drum brake adjusting screws
hydraulic hose (rear)
oil & oil filter
Carburetor
fuel pump
fuel filter
water pump
time chain
thermostat
coolant
Transmission fluid
Transmission filter
Things Left to do:
Driver side window
Rear window
Exhaust
Drive to adjust new brakes
Fine tune new carburetor
For Sale: $6,800
*I will help load or ship if needed.
New Radiator
New Fuel tank
Ignition lock
Ignition switch
Trunk lock
Horn ring
Radiator
Master cylinder
wheel cylinders
belts
radiator upper hose
radiator lower hose
brake pads (4 sets)
oil & oil filter
Carburetor
fuel pump
fuel filter
water pump
time chain
thermostat
coolant
Transmission fluid
Transmission filter
Things Left to do:
Driver side window
Rear window
Exhaust
For Sale: $6,800
