Jetblast
This car was listed as a project with everything to build a high end street car with 513 stroker motor with Trick Flow heads, full tube front end, drive train with 18 spline transmission and clutch style 3.55 rear.
Due to lack of interest, I am going to sell the car in pieces.
Body is mounted on a rotisserie and has been prepared for the paint shop. It has once more area to do on the right rear wheel well. It has new floors, trunk floor center section with cross member and is set up for a four speed. A complete frame stiffer package has been welded in and the body has been 90% seam sealed.
All glass is in tact. All door hardware is out and labeled.
Doors, trunk lid, hood, and front fenders are in epoxy primer, and are rust free. The hood is stock and comes with a Hemi scoop and template for the cut.
Body on rotisserie with stock front end parts, rear axle housing in primer and 3.55 Sure Grip, four 15" cop wheels and a k member assembly stand is $6500. All the above with qa-1 and PSA aftermarket front suspension, 7400.00
Rotisserie is gear drive unit. This first car done on it. 100's of in the process pictures are available, just hard to upload here.
Call or text 859-628-8911 with questions.
