it run fine no heating problem switches from floor to wind shield blower works good just no heat thought some one might know the problem off hand to cold to mess with it now think it may be a vacum thing ??? thanks RickIf I follow your question, you could have some issues like a non-working thermostat or one that doesn't open until higher engine temp, or a blocked core or hose. More checks could be the condition of the dash temp control vacuum setting not working. This could be disconnected or broken hose or nipple or linkage disconnect behind dash. There could be a ventilation damper not moving to allow heat, a quick check is to determine if you can move from floor blow to defrost blow settings...if the AC compressor isn't working you should still get heat...
