Odd Rod
I could not find a thread/post regarding rebuilding torsion bar front suspension I had seen earlier this year. Someone responded in that post and said to go ahead and rebuild the front end of my Plymouth and that I would learn a lot about my car. That reply was spot on. Thanks for the advice.
I used Kanter products to rebuild the front end and upgraded the drum brakes with a CSS disc brake setup from Classic Industries. The Kanter parts cost around $700 including new stock upper control arms. The disc brakes and proportion valve cost around $600.
It was a difficult but do-able task that I would also recommend for anyone that wants a better education on how their front suspensions is assembled and works. Seeing the car sit level on all four corners and feeling the steering/suspension work properly makes it all worth the effort.
Below are some photos of the severe wear on the original hardware. Chatting with the previous owner he mentioned the wear/deformation must be from "too many wheel stands". I also added a couple pics of the new components being installed - sway bar, control arms, disc brakes, etc. These components should do me just fine for street driving.
I will send out a follow-up once I get the front the front end aligned this week and get a few miles on the Plymouth.
