rtse66
for sale is a very solid 1966 plymouth belvedere II 2 door hardtop project car from the missouri/arkansas border area. has the original 318 motor in it but it's stuck. also has auto trans, PS, and PB. is all pretty much original except the correct 66/67 buckets have been added. will also come with the original bench seat if you want it. car is 99.5% complete, the things i see missing are the right door trim, a couple pieces of rear window trim the right side plymouth emblem on the 1/4 panel, headliner, carpet, and a couple of door panel trim pieces.
the car does have some rust on the lower 1/4 panel area and the rear of the rocker panels but the under side of the car is almost completely rust free, even the trunk extensions will not need to be replaced. the floor and trunk pans are exceptional in this car with just a little bit of rust thru in the front passenger floor pan. it would be an easy fix with POR 15 and wouldn't need panel replacement.
$2600 or B/O, any questions contact thru PM rob
