SOLD 1966 PLYMOUTH BELVEDERE I 360,904,3.55 8 3/4
WILLIAM COWGER
1:36 AM
APACHE JUNCTION AZ
1966 PLYMOUTH BELVEDERE I 360,904,3.55 8 3/4 , cruiser,footbrake racer,
has 9.1 360(built in 2010)low miles, I beam rods,KB coated skirt pistons,2.02 915J ,stainless valves,balanced assembly,cast stock 10/10 crank, 528/284 purple shaft mechanical, 5/16s moly pushrods,1.5 cast iron rockers, offy port o sonic,3310 holley 750, 1 5/8s patriot headers,dual exhaust,super turbo mufflers.2800 conv,b&m flex,904,rmvb,deep pan, balanced driveshafts with nos front and rear ends, back braced 8 3/4 3.55 clutch 742 (100 miles), car has new gas tank, 3/8s pickup,3/8s line, 11 inch brakes on rear, stock 10s on front,needs a disc brake kit, subframes are tied,new front to rear floor pans,rebuilt front suspension, 2 core 22 inch aluminum radiator,dual fans,trans cooler.100 amp powermaster alt.DC mechanical advance electronic distributor&msd6c.
body has had repair on lower rear quarters(done in late 90s), trunk is solid, frame rails are solid.nos 383 torsion bars, trans cooler,hurst shifter,gauges,tach,stock bench,seat belts,painted by maaco in 96.came out of MN via MO. have owners manual,certi card,broadcast sheet,fender tag, was 6 cyl new.ms,mb,radio delete. have owned since 2005. not a show car, was building it for a footbrake street legal drag car,retired and moved to AZ, no garage,paint is faded from sun,has rear main seal leak. ran 13.13@100 at US41 in 2015.more pics avail.
TURN KEY $20,000
OR ROLLER,LESS ENGINE,TRANS,3RD MEMBER,RADIATOR,TRANS COOLER,DRIVESHAFT, $15
