SOLD 1967 Charger
phish1270
11:12 AM
Iron Station, NC
1967 Dodge Charger, 383, 727 auto
Motor has 400 crank, Howard CL728001-09 Rattler cam, Lift: .480 / .488, Duration @ .050: 227 / 235, Centerline: 103, hardened valve seals, Edelbrock manifold, M/T crinkle finish valve covers, rebuilt with less than 500 miles on it so far
Transmission has been completely rebuilt, new PTC torque converter & B&M flexplate
Original 8.75 rear end with rebuilt 3.23 clutch style sure grip, green bearings
Manual brake system with disc brakes added up front & 11" drum added out back, brand new aluminum dual reservoir master cylinder (1 1/32" bore), all new brake lines, hoses, pads, calipers, wheel cylinders, shoes & hardware
Brand new American Racing VN501 Black 15"x8" & 15"x7" rims with Cooper Cobra 275/60/15 (rear) & 235/60/15 (front) tires
Fitech Go EFI 4 600HP Self-Tuning Throttle Body style fuel injection with fuel command center, a few mods made & some tweaking done for tuning so far.
Brand new Vintage Air Gen IV Surefit AC System, fully charged
Fully functioning Headlights with rebuilt motors, all new relays & headlights upgraded to H4 bulbs, new Dash wiring & front lighting harnesses, new headlight switch, LED bulbs & sequential turn signal kit for rear lights, electroluminescence works
Rebuilt Wiper motor
Aftermarket (hidden) stereo with 4 new speakers
All new carpeting, new front seat padding
Brand new, custom bent 2.5" exhaust with H-pipe, Summit mufflers, HiPo Mopar manifolds
New Grant Wooden steering wheel
Gas tank has been flushed out & new filler neck kit installed
Working fender turn signal indicators with led bulbs & new lenses
Battery relocated to trunk with master cut-off switch, custom panels made for trunk
Brand new aftermarket front 1 1/8" & rear 1" sway bars
Full front end kit from PST, new upper & lower control arm bushings, new tie rod ends & sleeves (larger C Body ones), upper & lower balljoints, strut rod bushings
New heavy duty torsion bars & leaf springs, new KYB Gas-a-just shocks all around
New motor & transmission mounts
Brand new 26" brass OE style radiator, all new hoses, belts, plugs, wires, cap, rotor, coil, alternator, battery (over-sized)
Brand new ready to run billet distributor
New washer squirt motor & reservoir
Lokar throttle & shifter cables
Firm feel, police spec steering box
All interior lights are led bulbs with new lenses
Tach has been updated with RTE tach board, other gauges are in process of being rebuilt professionally (thegaugedoc.com). Also has RTE voltage limiter installed.
Paint is driver quality, looks great from 10' away but there are chips & small scratches here & there. Supposedly was painted at some point in late 80's. This car is not perfect, it still needs some of the "little" things but it is all there. It would be hard to find a more rust free 52 year old car. This is a true southern car that has been in GA & NC its whole life.
Need car sold, getting ready to put oldest through college. Paid $12,500 for car in 2015, put over $20k into parts & services since buying not counting any of my labor.
Asking $20k as is, car is located in Iron Station, NC (28080)
More pictures available upon request. Feel free to ask any questions.
Look around, do your homework; you will not find one of these this rust free with this much done to it anywhere across the country. I see them for similar or more money with no working gauges, headlights don't open, old sagging suspensions, 318s. This is a big block car with efi, brand new (working) ac, disc brakes, power steering, upgraded suspension & brakes, Sure grip rear. I'm not hiding anything, engine & Sure grip, trans all rebuilt locally, tons of receipts. I'm just trying to get rid of some debt to help my son with college next year, my situation is your gain.
Anyone making offers before seeing the car will be deleted & blocked. No trades, no scams, no "deposits", don't need help selling.
20180605_201433.jpg CHARGER2.jpeg CHARGER5.jpeg CHARGER6.jpeg CHARGER7.jpeg CHARGER8.jpeg CHARGER9.jpeg CHARGER10.jpeg CHARGER11.jpeg CHARGER12.jpeg
