ORIGINAL PAINT, BODY PANELS, DRIVE TRAIN, NO BONDO ANYWHERE.
Also included, is a Jan 1970 date coded NON-HP 440 long block engine--on included stand-- with a pair of HP exhaust manifolds, 2 sets of complete heads. Also included is a big block 727 torque flight transmission.
The following parts have been installed since I have owned the car ...paid a local shop $1300 in labor to install all new brake system components, including all new lines, new parking brake cables installed for lt and rt rear, 4 new wheel cylinders, 3 new flex lines, NOS Timken race seals and bearing sets for front end, NOS rear drums, 4 new sets of shoes, spring kits, and a new master cylinder. I had the original Mopar radiator recored, also, new rad. hoses. Power steering pump sent out for overhaul, installed new pressure and return lines. Installed new gas tank with new mounting hardware, also, new filler neck installed. New fuel pump and filter. Overhauled driveshaft. New USA made battery with new pos and neg cables. New starter relay. New hood turn signal light assemblies. New Mallory electronic distributor installed with new coil, wires, and plugs. 4 new whitewall tires. Fresh oil change, filter and chassis lube.
Have receipts for all work done.
Also included is over $4000 in interior parts...Legendary Auto Interiors-all new door panels, carpeting, bucket seat covers and foam, rear seat and buddy seat covers, new head liner--all in their factory boxes. New gold steering wheel. A set of 4 Magnum 500 wheels-14"
