FOR SALE 1968 Charger H code body on frame jig, AMD panels
TexasRoadRunner68
8:49 AM
Dallas,Texas
Feedback: 1 / 0 / 0
Considering building a different car. I have a 68 H code car on a frame jig built using the 521 restorations blueprints. 3/16” tubing vs 1/8”, so it was built pretty stout. Has trailer jacks welded on to allow you to level the jig. The car needs most of the panels replaced. 3 of 4 frame rails are solid. The driver side needs replacement or patching. Driver a pillar has some rust, but a donor a pillar is included. Rockers are solid. No fender tag or front clip. Needs the works from AMD. Body numbers match. No rear end. I have the brand new AMD 68 tail panel, an AMD roof skin, the passenger quarter panel, and front driver frame rail. Clear blue Tx title.
Was thinking of asking $8500. Is that reasonable in todays market? I have nearly 2k in new AMD sheet metal along with the frame jig.
90A94D78-B6D3-4A06-B569-8F74DC7DB591.jpeg AE324486-2918-4C95-BE19-F8832D1CE14E.jpeg
Do you have the motor? What transmission was in the car. Is it column shift or floor shift with console? Do you have all the interior parts? Need a complete list of part's that come with car. Thanks, interested.
Finish it.
if you lost interest #s restoration than maybe go wild with it tubbed with a blown big block.
If it has a title and everything I’d say $8500 isn’t too crazy.
It was a floor shift auto. And no, I do not have the interior or any of the drivetrain. It’s a shell with a clean title. No fender tag, no build sheet, no trim. In todays market I doubt you’ll find a complete 68-70 charger, rusty or not, with a title, $2,400 in AMD sheetmetal (pretax) and a frame jig for $8500.
I might keep it and just build the body how I want it and go total resto mod with it.
Thank you for a reply. Just finished a 69 roadrunner. 5 and half year project. Interior part's missing was a nightmare to find. Like dash pad and other assorted pieces. Wish you luck on finishing the car. Blue.
$8500 might be a bit light, it would sell for sure for that much. I look at it this way: I probably wouldn't sell it for that much but pretty sure I would buy it for that much.
It’s a shell that needs almost everything. If I buy the 70 I might slowly work on this and just do the mini tubs, USCT chassis stiffening kit, full subframe connectors and maybe put something more modern in it with a 6 speed.
