1968 Charger R/T project
1968 -1970 Mopars
  1. Plymouthrocks
    Plymouthrocks FBBO Gold Member FBBO Gold Member
    135
    24
    Jul 20, 2014
    Elko Nevada
    Local Time:
    1:22 PM
    Question is with a 68 Charger R/T without a fender tag or build sheet can it be said that it is definitely an R/T by the vin? Is the value of the car really hurt by not having those two items. Any thoughts would be appreciated.
  2. The Rebel
    The Rebel Well-Known Member
    2,052
    2532
    Jul 19, 2016
    SW CT
    Local Time:
    4:22 PM
    Look at the VIN. Non R/T's start with XP, RT's start with XS.
    • Like Like x 1
    • Agree Agree x 1
    • 68Moparmaniac
      68Moparmaniac Well-Known Member
      814
      1302
      Jan 18, 2019
      Utah
      Local Time:
      2:22 PM
      If the vin number starts with XS29 (the tag on the dash) then it's the real deal. The 68 fender tags only show what options your car was born with along with the shipping sequence number down in the lower right hand corner. The vin number is the most important above all the nomenclature that the car was shipped with. You can have the fender tag remanufactured as well as the build sheet, but it's against the law as far as I know to remanufacture the vin tag. In order to recreate the fender tag you will have to do some detective work on your car, identifying the components that are with the car etc. Can be time consuming for sure.. good luck with your Charger :thumbsup:
      • Like Like x 1
      • Plymouthrocks
        135
        24
        Jul 20, 2014
        Elko Nevada
        Local Time:
        1:22 PM
        Just wondering if you guys were restoring a 1968 R/T and didn't have a numbers matching block would you use any 68 or any other bolck or spend $2000 more and buy a 1969 XS R/T H P block. Thanks for any thoughts.
      • Don selleck
        Don selleck FBBO Gold Member FBBO Gold Member
        1,468
        1856
        Aug 6, 2014
        michigan
        Local Time:
        4:22 PM
        depends on what your goona build, restomod no. factory correct or close too, yes.
        • Like Like x 1
        • Plymouthrocks
          135
          24
          Jul 20, 2014
          Elko Nevada
          Local Time:
          1:22 PM
          Do you guys know if a 1968 charger rt could have come with the hood pins as an option?
        • The Rebel
          2,052
          2532
          Jul 19, 2016
          SW CT
          Local Time:
          4:22 PM
          No hood pins. Here's a good reference website that will answer most of your questions: http://www.mymopar.com/index.php?pid=31
          • Like Like x 1
          • Richard Cranium
            Richard Cranium FBBO Gold Member FBBO Gold Member
            26,871
            61663
            Feb 20, 2012
            Local Time:
            3:22 PM
            The 5th digit on either a 68 or 69 Charger R/T should either be....
            L for 440 4 barrel
            J for 426 Hemi
          • 1968rt
            1968rt Well-Known Member
            118
            118
            Jul 28, 2010
            New York
            Local Time:
            4:22 PM
            I would think a date coded block would be fine even if its not from a Charger. Maybe you can get an idea of when it was built if someone has a vin close to yours. Why pay crazy money....it will never be numbers matching!
            • Like Like x 1
            • Plymouthrocks
              135
              24
              Jul 20, 2014
              Elko Nevada
              Local Time:
              1:22 PM
              Ok yea I am going the 68 motor but not a R/T block. Thanks for all the advice!
            1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
              By continuing to use this site, you are consenting to our use of cookies.
