Ok let me try and explain my issue. I bought my buddies 68 Charger from his wife when he passed away a few months ago. The car has a 500cu in. big block and a 4 speed in it with electric waterpump, electric fans etc......Basically alot of crap to draw on the charging system. Most of the wiring is newer and he was good at wiring so I doubt there are hacked sections. I did alot of it with him soldered connections etc....I am having issues with it overcharging. The car has an electronic ignition on it from Mopar Performance and still has the single field wire type regulator. So I buy a new "electronic regulator" (circuit board vs internal contacts) that will work with the single field wire setup and I have nothing.....zero. Went from over charging to nothing. I just installed the ground strap on the firewall from the engine block so that's a fresh ground that I sanded etc. I check voltage at the ignition side of the blue wire on regulator and it is the same as the battery so that side of circuit is fine. What should the output be on the field side??? I am getting 15.9 -16.3 at the alternator stud on the back of it and 10.1 at the field terminal on the regulator with the original overcharging regulator. Should I try another regulator or is there something more happening??? I am beginning to run out of ideas. I put another regulator on today and it goes way overcharge again, but this one was the mechanical style and spiked all over. Is this just to much draw for the single field style to handle? Wondering if I should do a dual field alternator and newer regulator style and that'll fix it? Any advice I am all ears.....Oh also, the gauge in the car and the aftermarket gauge both work and are both showing an overcharge in the circuit. Heres a few pics of the car for attention and some help...
