Rocketman
I have had this car as most of you know for 3 years going to car shows and cruise ins. It has a date correct 440 bored .060 over. I put an Edelbrock top end all aluminum kit on it last year keeping all the parts that came off. It has Hedman ceramic coated headers, Comp roller rockers and a Xtreme Energy .545 lift cam. MSD electronic ignition with MSD box with adjustable rev limiter. Phoenix Specialties powder coated the valve covers and breather top. It also has a vaccuum pump and tank for the brakes. Griffin all aluminum radiator with electric fan. Holley 3310 750 cfm carb. Dana 60 rear with 4 speed, I installed a hurst comp shifter but still have the inland shifter that came in it. The Video below shows it right I after getting it home from the engine build. The picture below show it right after getting it home after adding the 17" wheels and Nitto 555 radials. The booster and master cylinder seen the picture have been replaced and I also added KYB shocks and a Steer and Gear box. I have the build sheets for the car as well. Car is located in Murray, KY. Asking $45,900.
