Gregg DeGeorge
First off thanks for all your help ,I rewired the flasher which seemed to help ,It is strange how the colors change throughout the car . I have rear signals ,front and rear parking lights working ,have one problem still as soon as I turn key to run the black wire powers the flasher you can hear the flasher clicking away as if I put it in the turn position ,when you move the signal lever the blinkers come on , but when you center the stalk the blinkers shut off as they should but the flasher is clicking away as if the blinkers are on ..The black wire is steady power to flasher on the other side red wire to signal connection it’s already blinking before going up to signal switch lever .So they do work but still have something hooked up wrong thanks Again Gregg
