BigBlockBilly
I have a 69 Coronet 500 southwestern car for sale it has a 400 motor in it now with the 727 transmission, console shift and buckets with the drivers being a tilt. It was originally a 383 car. It has the close ratio power steering from the factory and I added the pitman / idler close ratio set for even more control. It has all new tires and rims.
I have the build sheet for the car it was under the rear seat cushion. It's painted yellow now but it's all there and is driven occasionally. New tires and rims. The motor is a 400 that was rebuilt before I had it and I installed a crane cam (272) the edelbrock intake, valve covers, aircleaner. The front housing is from 440 source and it has a new aluminum radiator. The carb is a 600 cfm edelbrock. The car was factory undercoated as per the build sheet. The car is in Tucson, AZ.
I'm asking $13500 for it.
