FOR SALE 1969 plymouth belvedere h code 383
FJ6 v code RR
11:48 AM
Collins Ohio 44826
Feedback: 2 / 0 / 0
Hi I have a project car. It's a very rare 1of 18 or less built and more then likely a 1 of 1 1969 plymouth belvedere h code 383 post car, it's also a 391 gear car with hemi suspension and power disc brake car and 26" radiator. I have the number matching engine and fender tag and build sheet and title for the car. It a project but a valuable car done. The belvedere is missing parts like the factory 1969 disc brakes and 391 center section and radiator. But I have factory disc brakes for the car just the 73 and newer style complete for b body and I have a date code correct 1969 489 case with 293 gears open.
The Interior is really nice driver quality correct bench seat interior. The dash is complete and lower dash pads are in real good shape. The correct original am radio is there as well.
Body- is in need of metal work. Someone tried to put a floor in out of another car and same for the trunk. So with that said I would put a new full floor in and I have a new amd 2 piece trunk floor and a full floor but full was damaged in shipping for it and one trunk extension still needs the other side also amd.
The quarter where cut to put new amd skins on. The skins are screw down for now the passenger side outer wheel well was put on and driver side need put on I have that as well. Also new amd door hinges.
Parts- I have alot of extra parts that go with the car.
The price for the car is $12,000 obo
I am located in collins ohio 44826
I also have a few different engine options I can sell with the car for extra money. There are 2 one is a 6.4 hemi with a 545rfe truck 2wd auto transmission
The other is a rebuilt 440 with 6 pack bottom end all balanced together and racer brown cam with double roller timing chain and rpm intake and Windage tray and oil sling.
I can also sell it all together as a package deal.
20210530_191857_copy_3024x2268.jpg 20210707_144228_copy_3024x2268.jpg 20210707_144258_copy_3024x2268.jpg 20210707_153458_copy_3456x2592.jpg 20210707_153330_copy_3456x2592.jpg 20210707_153141_copy_3456x2592.jpg 20210707_144210_copy_3024x2268.jpg 20210707_144052_copy_3024x2268.jpg 20210707_144012_copy_3024x2268.jpg 20210707_144047_copy_3024x2268.jpg
Agree, well done listing. Car is definitely a "sleeper". Would you mind posting a better scan of the build sheet. I would like to see what is on it. Thank you.
D
