1969 Plymouth GTX Body moldings
BruteForce1.
12:41 PM
SoCal
New to Mopars I have a 69 GTX I purchased car is complete painted but in pieces. I sent out a bunch of Chrome body moldings to get polished and trying to figure out where they go it seems like I have enough moldings for 2 or 3 cars any info or pics would be greatly appreciated, I apologize if this is not the correct place to post this, this is my first post, Thanks
The '69 GTX has a complex series of trim pieces that are unique to the model year. If you have all of them intact, you are a lucky guy. Reproductions are available, but the originals are impossible to find. The car uses five horizontal pieces on each side, in addition to the wheel well trim, all of them different lengths. I hope you hit a home run, and have everything you need. Picture shows my current car when it was new, with all the original factory pieces in place. The cars came from the factory with wire spring clips to anchor the trim, reproductions come with plastic tabs. The grill features two horizontal pieces made of anodized aluminum, and these are hard to find without dents. the windshield, rear window, and drip rail moldings are stainless steel.
Very front driver side...
Driver side front fender rear leg....
Driver side door....
Driver side rear quarter, front of rear wheel opening....
Driver side rear quarter behind rear wheel opening....
Reverse, rinse, and repeat for passenger side.....
Thanks for the photos really helps a lot, can I get the hardware to attach them to the body @ Sprin Fling. Heres a photo of everything I have
That all depends on which of the vendors show up, and what they brought with them for stock.
Shouldn't be too hard to sort out what's in your pile. Start by pulling out all the wheel opening moldings, then the front and rear windshield moldings....and the sill plates. What's left should be all of the body side moldings and whatever pieces you have for the front grill upper and lower pieces.
If anything else is left after that, shouldn't be too hard to figure out where they go.
Those look like the trim that goes above the interior door panels
You really hit a home run if you have everything. Fingers crossed for you.
