Hi I am looking for 1970 b body and e body disc brake setup I am looking for caliper bracket to spindle bolts and spindle to lower ball joint bolts. May also be looking for caliper bracket. The pictures are of the bolts I am looking for. Let me know in pm what you have and prices thanks Duane.
I have USA (N.O.S.) and the Chineseum Front Disc brake rotors and N.O.S. ++ Asbestos ++ brake pads and a whole lot more ...... If you want to do this car right..... Yours, Craig
FWIW The spindle to ball joint bolts you have pictured are not correct for 70, they are 73 & up... 70 used a castled nut with a cotter pin & a bolt with a hole for the cotter pin.... If you truly want it right thats what you want... If you just want it o work the 73 design is better cause you can torque to spec & stop, with the 70 design if the holes don't line up you need to torque further till the cotter pin will pass through.... Usually it's fine but sometimes it's a real problem...
