WTB 1970 Challenger Front Caliper Bracket
Go Fly
10:43 AM
Feedback: 1 / 0 / 0
Looking for a front caliper bracket.
I think its the left I need. The one I have is p/n KH80034.
The side I need might be p/n KH80035?
The spare that I have is in a box marked 70/71 B/E caliper support bracket rh... but it sure looks concentric to me. 3.5" c/c on large holes, 5 3/8" c/c on the small threaded "pin" holes and approx 3 1/8" c/c from small hole to big hole. Has an H-70 on it and vendor #86152
They look concentric but they aren't... Got a spindle? It won't bolt to the wrong spindle...
Looks really close. I did some measuring and the spacing might be a little narrower?
Hello Go Fly, do you still have the KH 80034?
i may need one, i have bent spindle or caliper bracket, not sure how to check either one but my brake pads are wearing out slanted and pulling to that side, so its either the spindle or the bracket, i ordered a spindle, if that doesn't fix it, i will swap out the bracket next, the one i pulled off is in the pics below (KH 80034) and the pads.
Thank you
Hi,
I hope the spindle solves the problem. I need to keep the one side I have as would still like to find the correct other. Keep me posted and perhaps I can help in some way.
