1970 Charger steering column rebuild!
vita
5:29 AM
El Paso, TX
Just finished rebuilding my steering column for the 1970 Charger. Figure if any one is looking to do it as well, you can see what it entails! I try to do these videos to help anyone else who might be trying to tackle the same projects that I am! I'm sure I might need to swap something around when it comes time to install, however, 90% close is better than what I started with!
Be sure and check that your brake lights still come on in all turn signal settings after replacing the turn signal switch. I've had bad luck with the aftermarket turn signal switches. Also some are hard to manually cancel.
