1970 Mopar exhaust manifold heat riser
68 440+6 R/T
8:51 PM
USA
does any body know the correct way to weld on the heat riser plate and which was the bimetallic spring is supposed to go? When welding it on is there supposed to be tension on the spring or no tension?
The kit I bought 25 years ago had decent instructions, which I really don't remember. I do remember the large bimetal spring had tension enough to keep the flap closed when cold. Hope this helps some.
The following image shows the instruction sheet from the Chrysler 3683947 Manifold Heat Control Package:
The instructions describe the handling of the spring.
Also attached is a PDF of the instruction sheet that might be more usable.
